37-610 Bullet
Don't know factory or not, but it looks like a removable cover/plug and seems to give access to the RF chassis' adjustment parts (trimmers etc), so this is probably what it is. It then should be replaced after the alignment.
37-610 Bullet - by Tucker - 04-17-2019, 08:01 PM
RE: 37-610 Bullet - by morzh - 04-17-2019, 09:25 PM
RE: 37-610 Bullet - by Tucker - 04-18-2019, 07:35 AM
RE: 37-610 Bullet - by morzh - 04-18-2019, 08:34 AM
RE: 37-610 Bullet - by Jake Blake - 04-18-2019, 08:50 AM
RE: 37-610 Bullet - by Ron Ramirez - 04-20-2019, 09:30 AM
RE: 37-610 Bullet - by morzh - 04-20-2019, 09:03 PM
