Philco 21
Here's some more, of the back; uncleaned as found condition of course...
Wonder what that hole is for on the top arch?
notice that shim (on right side only) holding the chassis up?
the shaft holes in the front are not centered, wondering whats going on!
lots of tree leaves and junk
the 3 tubes left to right are 45, 80, and UX-245
Philco 21 - by Simon Wa3uay - 04-17-2019, 03:44 PM
RE: Philco 21 - by Radioroslyn - 04-17-2019, 04:04 PM
RE: Philco 21 - by Simon Wa3uay - 04-18-2019, 03:21 PM
RE: Philco 21 - by Radioroslyn - 04-18-2019, 05:13 PM
RE: Philco 21 - by GarySP - 04-19-2019, 11:50 AM
RE: Philco 21 - by Simon Wa3uay - 04-19-2019, 02:25 PM
RE: Philco 21 - by Simon Wa3uay - 04-19-2019, 02:28 PM
RE: Philco 21 - by morzh - 04-19-2019, 06:25 PM
