Re-stuffing metal bodied capacitors.
#33
What I used can be considered a small hack saw. After cutting I dress the cut on each side by sanding (or filing) down each side, then rejoining with JB Weld. The cut is disguised by the structure under the cap.
I also prefer this over cutting at the bottom because it makes the can stronger, in case the chassis is handled by the can or if the can is bumped.
RE: Re-stuffing metal bodied capacitors. - by Kestas - 04-20-2019, 09:49 PM
91H Code 126 Restore
There are currently 2739 online users. [Complete List]
» 1 Member(s) | 2738 Guest(s)
