50T Canadian-made
Review post five and click on the link.
https://www.philcoradio.com/phorum/showt...?tid=19887
50T Canadian-made - by CharcBait - 04-21-2019, 03:40 AM
RE: 50T Canadian-made - by KCMike - 04-21-2019, 07:08 AM
RE: 50T Canadian-made - by Radioroslyn - 04-21-2019, 10:24 AM
RE: 50T Canadian-made - by Brad Winder - 05-04-2019, 01:19 AM
RE: 50T Canadian-made - by CharcBait - 05-04-2019, 09:44 PM
