Threads: 55
City: Lexington, KY
Yeah, that would be best to just gut and then install new resistors in the original can or some under chassis if all won't fit in the can.
Very nice job so far Mike!
RE: Another 7G605 Zenith TO - by Eliot Ness - 04-22-2019, 06:07 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
