Another 7G605 Zenith TO
#48
Here it is.
The theory proved correct, the Candom leaks the potential to the case.
Once taken off and then soldered without touching the chassis, the hum stops completely.
The case measures 123V to chassis which indicates that the leakage occurs right at the top lead where it is 125V.
I am going to completely open it to look for obvious reasons, and if not found, I will replace it.
The problem is, the main wall and the screw hole are actually the Candohm itself so there is no complete box to restuff.
Another 7G605 Zenith TO - by morzh - 03-17-2019, 07:01 PM
RE: Another 7G605 Zenith TO - by EdHolland - 03-18-2019, 10:52 PM
RE: Another 7G605 Zenith TO - by morzh - 03-18-2019, 11:34 PM
RE: Another 7G605 Zenith TO - by EdHolland - 03-19-2019, 11:56 AM
RE: Another 7G605 Zenith TO - by morzh - 03-19-2019, 01:17 PM
RE: Another 7G605 Zenith TO - by morzh - 03-23-2019, 05:50 PM
RE: Another 7G605 Zenith TO - by Eliot Ness - 03-23-2019, 06:14 PM
RE: Another 7G605 Zenith TO - by morzh - 03-23-2019, 08:18 PM
RE: Another 7G605 Zenith TO - by WyTex - 03-24-2019, 06:58 AM
RE: Another 7G605 Zenith TO - by morzh - 03-24-2019, 10:20 AM
RE: Another 7G605 Zenith TO - by EdHolland - 03-24-2019, 10:38 AM
RE: Another 7G605 Zenith TO - by Ron Ramirez - 03-24-2019, 11:32 AM
RE: Another 7G605 Zenith TO - by Paul Philco322 - 03-24-2019, 11:37 AM
RE: Another 7G605 Zenith TO - by morzh - 03-24-2019, 12:15 PM
RE: Another 7G605 Zenith TO - by Phlogiston - 03-24-2019, 01:07 PM
RE: Another 7G605 Zenith TO - by morzh - 03-24-2019, 02:15 PM
RE: Another 7G605 Zenith TO - by morzh - 03-24-2019, 06:14 PM
RE: Another 7G605 Zenith TO - by morzh - 03-27-2019, 11:19 AM
RE: Another 7G605 Zenith TO - by morzh - 03-27-2019, 09:13 PM
RE: Another 7G605 Zenith TO - by radiohenry - 03-28-2019, 09:39 PM
RE: Another 7G605 Zenith TO - by morzh - 03-29-2019, 09:36 AM
RE: Another 7G605 Zenith TO - by TV MAN - 03-29-2019, 09:56 AM
RE: Another 7G605 Zenith TO - by morzh - 03-29-2019, 11:01 AM
RE: Another 7G605 Zenith TO - by morzh - 04-02-2019, 09:56 AM
RE: Another 7G605 Zenith TO - by morzh - 04-02-2019, 07:37 PM
RE: Another 7G605 Zenith TO - by morzh - 04-02-2019, 07:41 PM
RE: Another 7G605 Zenith TO - by Ron Ramirez - 04-02-2019, 09:38 PM
RE: Another 7G605 Zenith TO - by morzh - 04-02-2019, 10:29 PM
RE: Another 7G605 Zenith TO - by Ron Ramirez - 04-03-2019, 06:01 AM
RE: Another 7G605 Zenith TO - by Eliot Ness - 04-03-2019, 07:46 AM
RE: Another 7G605 Zenith TO - by morzh - 04-03-2019, 08:47 AM
RE: Another 7G605 Zenith TO - by morzh - 04-03-2019, 09:20 PM
RE: Another 7G605 Zenith TO - by morzh - 04-05-2019, 08:54 PM
RE: Another 7G605 Zenith TO - by morzh - 04-07-2019, 05:47 PM
RE: Another 7G605 Zenith TO - by morzh - 04-09-2019, 07:37 PM
RE: Another 7G605 Zenith TO - by morzh - 04-10-2019, 03:11 PM
RE: Another 7G605 Zenith TO - by WyTex - 04-10-2019, 04:09 PM
RE: Another 7G605 Zenith TO - by morzh - 04-10-2019, 04:48 PM
RE: Another 7G605 Zenith TO - by morzh - 04-10-2019, 09:03 PM
RE: Another 7G605 Zenith TO - by morzh - 04-14-2019, 05:13 PM
RE: Another 7G605 Zenith TO - by morzh - 04-18-2019, 02:59 PM
RE: Another 7G605 Zenith TO - by morzh - 04-22-2019, 01:36 PM
RE: Another 7G605 Zenith TO - by Eliot Ness - 04-22-2019, 02:34 PM
RE: Another 7G605 Zenith TO - by morzh - 04-22-2019, 04:35 PM
RE: Another 7G605 Zenith TO - by Eliot Ness - 04-22-2019, 06:07 PM
RE: Another 7G605 Zenith TO - by morzh - 04-22-2019, 10:49 PM
RE: Another 7G605 Zenith TO - by morzh - 04-23-2019, 07:59 PM
RE: Another 7G605 Zenith TO - by morzh - 04-24-2019, 02:05 PM
RE: Another 7G605 Zenith TO - by morzh - 04-25-2019, 08:28 PM
RE: Another 7G605 Zenith TO - by morzh - 04-28-2019, 06:57 PM
RE: Another 7G605 Zenith TO - by WyTex - 04-29-2019, 07:09 AM
RE: Another 7G605 Zenith TO - by morzh - 04-29-2019, 08:07 AM
RE: Another 7G605 Zenith TO - by morzh - 04-30-2019, 09:26 PM
RE: Another 7G605 Zenith TO - by EdHolland - 04-30-2019, 10:06 PM
RE: Another 7G605 Zenith TO - by WyTex - 05-01-2019, 11:54 AM
RE: Another 7G605 Zenith TO - by morzh - 05-01-2019, 01:51 PM
RE: Another 7G605 Zenith TO - by Eliot Ness - 05-01-2019, 02:08 PM
RE: Another 7G605 Zenith TO - by morzh - 05-06-2019, 09:33 AM
RE: Another 7G605 Zenith TO - by KCMike - 05-06-2019, 09:59 AM
RE: Another 7G605 Zenith TO - by morzh - 05-06-2019, 10:44 AM
RE: Another 7G605 Zenith TO - by morzh - 05-15-2019, 08:30 PM
RE: Another 7G605 Zenith TO - by jake wells - 05-15-2019, 11:50 PM
RE: Another 7G605 Zenith TO - by morzh - 05-16-2019, 07:50 AM
RE: Another 7G605 Zenith TO - by morzh - 05-16-2019, 08:28 PM
RE: Another 7G605 Zenith TO - by rfeenstra - 05-17-2019, 12:29 AM
RE: Another 7G605 Zenith TO - by Eliot Ness - 05-17-2019, 07:19 AM
RE: Another 7G605 Zenith TO - by morzh - 05-17-2019, 09:00 AM
RE: Another 7G605 Zenith TO - by morzh - 05-24-2019, 10:51 AM
RE: Another 7G605 Zenith TO - by morzh - 05-25-2019, 10:03 PM
RE: Another 7G605 Zenith TO - by morzh - 05-26-2019, 03:01 PM
RE: Another 7G605 Zenith TO - by Eliot Ness - 05-26-2019, 06:33 PM
RE: Another 7G605 Zenith TO - by morzh - 05-26-2019, 06:57 PM
RE: Another 7G605 Zenith TO - by morzh - 05-27-2019, 08:51 PM
RE: Another 7G605 Zenith TO - by KCMike - 05-27-2019, 08:55 PM
RE: Another 7G605 Zenith TO - by morzh - 05-27-2019, 09:29 PM
RE: Another 7G605 Zenith TO - by EdHolland - 06-01-2019, 11:18 PM
RE: Another 7G605 Zenith TO - by morzh - 06-02-2019, 10:01 AM
