Looks like Philco 84b, but? Help!
Obtw name is Terry, GL is for good luck.
Am pretty well versed on the 84B so fire away w/any questions.
For starters bakelite encased foil /paper caps need to be replaced along w/ the electrolytics.
Check all carbon comp resistors for tolerance of 20% of stated value. The high value ones around the detector are suspect.
It's fairly common for the ant and osc coils to have an open primary winding. If found to be true it's pretty simple to repair/rewind.
Using a signal generator to do the IF and RF alignment is a good idea. If you just do it willy nilly  by ear the performance will suffer.
Looks like Philco 84b, but? Help! - by DadsPhilco - 04-23-2019, 08:03 PM
RE: Looks like Philco 84b, but? Help! - by morzh - 04-23-2019, 08:33 PM
RE: Looks like Philco 84b, but? Help! - by Radioroslyn - 04-26-2019, 02:50 PM
91H Code 126 Restore
