Philco 49-909
I'm trying to figure this out...So, I have a paper cap that states .04mfd 400 wvdc. I don't see a .04 mfd on justradios...I take it this can be substituted with something else? Like .0047uF @ 630V maybe? Also, the black stripe on the end of the paper caps..is that the + end?
Philco 49-909 - by dos0711 - 11-23-2010, 09:32 AM
Re: Philco 49-909 - by codefox1 - 11-23-2010, 01:44 PM
Re: Philco 49-909 - by Carl Travis - 11-23-2010, 03:27 PM
Re: Philco 49-909 - by dos0711 - 11-23-2010, 03:35 PM
Re: Philco 49-909 - by Ron Ramirez - 11-23-2010, 04:55 PM
Re: Philco 49-909 - by dos0711 - 11-24-2010, 03:58 PM
Re: Philco 49-909 - by codefox1 - 11-24-2010, 05:01 PM
Re: Philco 49-909 - by dos0711 - 11-25-2010, 12:57 PM
Re: Philco 49-909 - by codefox1 - 11-25-2010, 01:56 PM
