What do I have here?
https://philcoradio.com/gallery2/1949a/#Model_49-603
Standard ac/dc set w/an odd cabinet.
What do I have here? - by Chris h - 05-04-2019, 10:13 PM
RE: What do I have here? - by Radioroslyn - 05-04-2019, 10:21 PM
RE: What do I have here? - by Chris h - 05-05-2019, 10:19 AM
