Gozinta
#49
>>>Does the Deoxit Fader Lube come in an aerosol can with a straw? I'm thinking simple, like maybe an adaptor to connect an aerosol straw to the control. Any thoughts?
(Steve Davis).
John
Good find, and exactly what Steve suggested.
This would work better for the panel-mount pots, as in small radios like my Zenith T/O the pot is mounted on a separate bracket that then is screwed to the chassis, so one won't be able to just screw it on - it will require disassembly.
TrolMaster, on the other hand, is long and axial so it accesses this kind of locations.
I wonder if Steve could make the Gozinta analog in limited qtys - many folks here would be interested.
The adapter is straightforward, and the access for the aerosol can tube probably should have some gasket in it so the stuff doesn't just get sprayed back outside.
Gozinta - by Eliot Ness - 02-12-2019, 05:14 PM
RE: Gozinta - by Ron Ramirez - 02-15-2019, 10:57 PM
RE: Gozinta - by Ron Ramirez - 02-15-2019, 11:04 PM
RE: Gozinta - by 462ron - 02-15-2019, 11:48 PM
RE: Gozinta - by KCMike - 02-16-2019, 12:44 PM
RE: Gozinta - by EdHolland - 02-16-2019, 12:54 PM
RE: Gozinta - by morzh - 02-16-2019, 05:38 PM
RE: Gozinta - by 462ron - 02-16-2019, 10:36 PM
RE: Gozinta - by 462ron - 02-17-2019, 11:59 PM
RE: Gozinta - by morzh - 02-18-2019, 12:22 AM
RE: Gozinta - by 462ron - 02-18-2019, 10:53 AM
RE: Gozinta - by morzh - 02-18-2019, 11:51 AM
RE: Gozinta - by 462ron - 02-18-2019, 04:46 PM
RE: Gozinta - by morzh - 02-18-2019, 04:57 PM
RE: Gozinta - by EdHolland - 02-18-2019, 07:12 PM
RE: Gozinta - by 462ron - 02-18-2019, 07:24 PM
RE: Gozinta - by morzh - 02-22-2019, 07:19 PM
RE: Gozinta - by 462ron - 02-22-2019, 07:38 PM
RE: Gozinta - by morzh - 02-22-2019, 08:19 PM
RE: Gozinta - by 462ron - 02-22-2019, 09:14 PM
RE: Gozinta - by morzh - 02-22-2019, 10:08 PM
RE: Gozinta - by Eliot Ness - 02-23-2019, 11:14 PM
RE: Gozinta - by morzh - 02-23-2019, 11:36 PM
RE: Gozinta - by Eliot Ness - 05-06-2019, 02:51 PM
RE: Gozinta - by morzh - 05-06-2019, 03:06 PM
RE: Gozinta - by Phlogiston - 05-06-2019, 03:13 PM
RE: Gozinta - by morzh - 05-06-2019, 04:00 PM
RE: Zenith 5G500 - by morzh - 02-12-2019, 06:09 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-12-2019, 07:02 PM
RE: Zenith 5G500 - by David - 02-12-2019, 09:30 PM
RE: Zenith 5G500 - by Eliot Ness - 02-13-2019, 03:54 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-13-2019, 04:03 PM
RE: Zenith 5G500 - by EdHolland - 02-13-2019, 05:45 PM
RE: Zenith 5G500 - by morzh - 02-13-2019, 06:13 PM
RE: Zenith 5G500 - by Steve Davis - 02-13-2019, 09:17 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-13-2019, 10:42 PM
RE: Zenith 5G500 - by KCMike - 02-13-2019, 11:08 PM
RE: Zenith 5G500 - by KCMike - 02-14-2019, 01:40 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-14-2019, 01:45 PM
RE: Zenith 5G500 - by morzh - 02-14-2019, 02:37 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:07 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 01:09 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:09 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 01:12 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:17 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 01:21 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:25 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 05:38 PM
RE: Zenith 5G500 - by Steve Davis - 02-15-2019, 10:06 PM
RE: Zenith 5G500 - by Steve Davis - 02-15-2019, 10:07 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 10:21 PM
