Painted Stewart-Warner 03-5S2
Other than the baby blue paint the case seems solid, so maybe some citrus strip and could be saved.
They made a pretty good set.
Painted Stewart-Warner 03-5S2 - by Jake Blake - 05-06-2019, 11:42 PM
RE: Painted Stewart-Warner 03-5S2 - by Eliot Ness - 05-07-2019, 08:36 AM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 05-07-2019, 09:06 AM
RE: Painted Stewart-Warner 03-5S2 - by Paul Philco322 - 05-07-2019, 09:02 PM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 05-07-2019, 09:13 PM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 05-08-2019, 10:23 AM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 02-19-2020, 09:10 PM
RE: Painted Stewart-Warner 03-5S2 - by David - 02-19-2020, 09:50 PM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 02-19-2020, 10:07 PM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 02-19-2020, 10:11 PM
RE: Painted Stewart-Warner 03-5S2 - by David - 02-20-2020, 02:30 PM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 02-20-2020, 11:58 PM
RE: Painted Stewart-Warner 03-5S2 - by RodB - 02-21-2020, 10:30 AM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 02-21-2020, 02:51 PM
RE: Painted Stewart-Warner 03-5S2 - by Jake Blake - 03-20-2020, 10:16 PM
Philco 91 Tuning Condenser
