Does this radio/phono exist?
...or she's is thinking of 33 1/3 rpm records rather than 45s. It did play those. http://www.nostalgiaair.org/pagesbymodel...014067.pdf
Does this radio/phono exist? - by irawex - 05-09-2019, 08:33 AM
RE: Does this radio/phono exist? - by klondike98 - 05-09-2019, 09:31 AM
RE: Does this radio/phono exist? - by morzh - 05-09-2019, 11:52 AM
RE: Does this radio/phono exist? - by Jake Blake - 05-09-2019, 03:44 PM
RE: Does this radio/phono exist? - by klondike98 - 05-09-2019, 07:23 PM
RE: Does this radio/phono exist? - by Ron Ramirez - 05-09-2019, 08:55 PM
RE: Does this radio/phono exist? - by irawex - 05-11-2019, 10:56 PM
There are currently 10187 online users. [Complete List]
» 1 Member(s) | 10186 Guest(s)
