1936 Rca C8-19 video
Wink
finally got the chassis done the audio is over powering the microphone in my phone this set is LOUD!  Icon_biggrin
playing oldies from WRUS am 610.
https://www.youtube.com/watch?v=liocSBeD...e=youtu.be
1936 Rca C8-19 video - by jake wells - 05-14-2019, 11:27 PM
RE: 1936 Rca C8-19 video - by Eliot Ness - 05-15-2019, 08:10 AM
RE: 1936 Rca C8-19 video - by Jake Blake - 05-15-2019, 08:12 AM
RE: 1936 Rca C8-19 video - by PhilcoJohn - 05-23-2019, 06:49 AM
There are currently 10793 online users. [Complete List]
» 2 Member(s) | 10791 Guest(s)
