An Unknown radio restoration
Looks similar to one of those gothic GE J-series models.
An Unknown radio restoration - by OldRestorer - 05-15-2019, 07:28 PM
RE: An Unknown radio restoration - by OldRestorer - 05-15-2019, 07:30 PM
RE: An Unknown radio restoration - by Ron Ramirez - 05-15-2019, 07:32 PM
RE: An Unknown radio restoration - by OldRestorer - 05-15-2019, 07:34 PM
RE: An Unknown radio restoration - by OldRestorer - 05-15-2019, 07:37 PM
RE: An Unknown radio restoration - by OldRestorer - 05-15-2019, 07:38 PM
RE: An Unknown radio restoration - by OldRestorer - 05-15-2019, 07:40 PM
RE: An Unknown radio restoration - by morzh - 05-15-2019, 08:49 PM
RE: An Unknown radio restoration - by David - 05-15-2019, 09:53 PM
RE: An Unknown radio restoration - by Eliot Ness - 05-15-2019, 11:04 PM
RE: An Unknown radio restoration - by Jake Blake - 05-15-2019, 11:22 PM
RE: An Unknown radio restoration - by klondike98 - 05-16-2019, 06:08 PM
RE: An Unknown radio restoration - by Joe Rossi - 05-18-2019, 11:44 AM
There are currently 11391 online users. [Complete List]
» 2 Member(s) | 11389 Guest(s)
