Philco Model 70 volume and reception problems
My radio lose its volume after being played for a while .athen the volume comes back up.Also During reception ,the radio blanks out and has anoise level that is not affected by the volume control .It is a sort of hissing staticky sound.After i turn off the radioand it cools down , it plays fine for a while after turning it on, then it does the low volume and no reception thing again.I will appreciate any help I can get. Claude
Philco Model 70 volume and reception problems - by radionut - 11-28-2010, 10:03 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
