B+ voltage discrepancies between rect tubes
CHS should be Chatham, basically Tung-Sol's division that produced mil spec and other speciality tubes.
Without knowing voltage specs, no clue if one is high or other is low. Not uncommon for B+ to vary 5-10v on different new tubes but 30v is excessive.
Tom
RE: B+ voltage discrepancies between rect tubes - by 35Z5 - 05-18-2019, 07:36 PM
There are currently 4811 online users. [Complete List]
» 2 Member(s) | 4809 Guest(s)
