Model 37 Series Code 121
Hi Terry
It looks like this, correct?
http://www.philcoradio.com/gallery/1932c.htm#b
Model 37 was a battery-operated receiver that Philco introduced in Fall 1932. Besides this table model cabinet, it was also available as a console.
Model 37 is roughly the battery-operated equivalent of Model 52.
Model 37 Series Code 121 - by terry h - 11-28-2010, 04:14 PM
Re: Model 37 Series Code 121 - by Ron Ramirez - 11-28-2010, 04:26 PM
Re: Model 37 Series Code 121 - by terry h - 11-28-2010, 06:18 PM
