Need help ID'ing console ('29 Model 65?)
OK, now that I've gone through it I've found 4 transformers out on this guy. I've located a used model 65 power supply, but still need to track down the rest (including whatever's blown on the speaker.)
Couple of question on this:
- The second filter choke is open. Specs are 150H, 10ma, 4000 ohms winding. Hammond makes a 150H, 8ma, 3700 ohm model. Is this close enough?
- Can't find any info on the push-pull transformer to the two 45 tubes. I believe this is called the "audio interstage" transformer; it sits between the 27 tube and the 2 - 45's. #17 on the schematic. What can I use on these? Looks like Hammond has a handful of "generic" varieties.
[No subject] - by Chuck Schwark - 01-31-2006, 12:21 AM
[No subject] - by noiseguy - 01-31-2006, 09:55 AM
[No subject] - by Ron Ramirez - 01-31-2006, 09:59 AM
[No subject] - by Chuck Schwark - 01-31-2006, 10:03 AM
[No subject] - by Ron Ramirez - 01-31-2006, 01:06 PM
[No subject] - by rjm - 01-31-2006, 03:33 PM
[No subject] - by noiseguy - 02-01-2006, 11:40 PM
[No subject] - by Chuck Schwark - 02-01-2006, 11:52 PM
[No subject] - by noiseguy - 02-02-2006, 05:09 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:44 PM
[No subject] - by noiseguy - 02-17-2006, 01:09 PM
[No subject] - by rjm - 02-17-2006, 02:15 PM
[No subject] - by noiseguy - 03-27-2006, 12:45 AM
[No subject] - by rjm - 03-27-2006, 02:01 AM
[No subject] - by noiseguy - 03-27-2006, 09:12 AM
[No subject] - by noiseguy - 03-27-2006, 09:34 AM
Eico 232 VTVM Schematic
There are currently 8739 online users. [Complete List]
» 1 Member(s) | 8738 Guest(s)
