Spring for vernier for 37-610T
I have a Philco 623 and decided to take apart and clean the vernier dial drive. After it exploded on me and I managed to find the parts that flew, I couldn't figure out what held the inner shaft in place till I read this post and found another page that showed how it works. Anyway, it appears that the ball on the end of my inner shaft came off. If I look under a magnifing glass I can see a line around the ball where it matches up to the end of the shaft. So my question is, is the ball glued to the inner shaft ? can it be reglued with super glue or ?
Thanks !
Tim
Spring for vernier for 37-610T - by Steve D - 01-19-2010, 10:11 AM
Re: Spring for vernier for 37-610T - by Steve D - 01-26-2010, 01:43 PM
Re: Spring for vernier for 37-610T - by Steve D - 01-26-2010, 06:34 PM
Re: Spring for vernier for 37-610T - by timh - 11-28-2010, 04:52 PM
Re: Spring for vernier for 37-610T - by TA Forbes - 12-03-2010, 11:11 PM
Eico 232 VTVM Schematic
There are currently 3186 online users. [Complete List]
» 2 Member(s) | 3184 Guest(s)
