Philco 20, 21, 90 or what?
Methinks it is a mongre.
Someone took a 20 chassis, added a 4th knob (the 20 has 3, so whatever that 4th knob does.....a mod in the chassis?) and stuck it into a 90 cabinet.
And no it is not a 21 cabinet with 90 trim, it is a 90 cabinet (the top of the 90 is very characteristic and can always be told from the 70, and the 21 has it like the 70 does).
Philco 20, 21, 90 or what? - by Robin in Kansas - 05-22-2019, 12:00 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 12:14 PM
RE: Philco 20, 21, 90 or what? - by morzh - 05-22-2019, 01:11 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 01:15 PM
RE: Philco 20, 21, 90 or what? - by morzh - 05-22-2019, 01:16 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 01:34 PM
RE: Philco 20, 21, 90 or what? - by Radioroslyn - 05-22-2019, 02:29 PM
RE: Philco 20, 21, 90 or what? - by Steve Davis - 05-22-2019, 02:30 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 02:35 PM
RE: Philco 20, 21, 90 or what? - by morzh - 05-22-2019, 02:50 PM
RE: Philco 20, 21, 90 or what? - by Ron Ramirez - 05-22-2019, 05:43 PM
Philco 91 Tuning Condenser
