Philco 20, 21, 90 or what?
Mike is correct, this is a 90 cabinet. The top of the arch has a little more of a peak than the 21. Also, if you look at the rear, you can see there is about a 1/2 inch space between the chassis and the side of the cabinet and the back edge of the chassis is about an inch from the back of the cabinet. Now, what I cant explain is the shaft spacing. Obviously,  a tone control has been added but the spacing of the two outer controls would have to be widened to match the holes in the 90 front panel.
M R Radios   C M Tubes
Philco 20, 21, 90 or what? - by Robin in Kansas - 05-22-2019, 12:00 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 12:14 PM
RE: Philco 20, 21, 90 or what? - by morzh - 05-22-2019, 01:11 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 01:15 PM
RE: Philco 20, 21, 90 or what? - by morzh - 05-22-2019, 01:16 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 01:34 PM
RE: Philco 20, 21, 90 or what? - by Radioroslyn - 05-22-2019, 02:29 PM
RE: Philco 20, 21, 90 or what? - by Steve Davis - 05-22-2019, 02:30 PM
RE: Philco 20, 21, 90 or what? - by klondike98 - 05-22-2019, 02:35 PM
RE: Philco 20, 21, 90 or what? - by morzh - 05-22-2019, 02:50 PM
RE: Philco 20, 21, 90 or what? - by Ron Ramirez - 05-22-2019, 05:43 PM
There are currently 3867 online users. [Complete List]
» 1 Member(s) | 3866 Guest(s)
