Need help ID'ing console ('29 Model 65?)
Hi, I too have a bad interstage transformer on my 87. I ordered the hamond 124a they say it will work. As for the chokes check Play things of past on the resourse page. When looking for the interstage trans I saw Philco chokes for model 87 I believe they are the same for your 65 and other models. The Philco work bench web sight gives part #'s. Just look under PHILCO RADIO PART VALUES. Check them out it won't hurt
Hope this helps, Richard
[No subject] - by Chuck Schwark - 01-31-2006, 12:21 AM
[No subject] - by noiseguy - 01-31-2006, 09:55 AM
[No subject] - by Ron Ramirez - 01-31-2006, 09:59 AM
[No subject] - by Chuck Schwark - 01-31-2006, 10:03 AM
[No subject] - by Ron Ramirez - 01-31-2006, 01:06 PM
[No subject] - by rjm - 01-31-2006, 03:33 PM
[No subject] - by noiseguy - 02-01-2006, 11:40 PM
[No subject] - by Chuck Schwark - 02-01-2006, 11:52 PM
[No subject] - by noiseguy - 02-02-2006, 05:09 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:44 PM
[No subject] - by noiseguy - 02-17-2006, 01:09 PM
[No subject] - by rjm - 02-17-2006, 02:15 PM
[No subject] - by noiseguy - 03-27-2006, 12:45 AM
[No subject] - by rjm - 03-27-2006, 02:01 AM
[No subject] - by noiseguy - 03-27-2006, 09:12 AM
[No subject] - by noiseguy - 03-27-2006, 09:34 AM
