Characteristics and components of vacuum tubes
Thanks to all those who responded to my tube characteristics and component inquiry. Your help, efforts and concern are very much appreciated.
Floyd
Re: Characteristics and components of vacuum tubes - by Radionut78 - 11-29-2010, 04:18 PM
