Threads: 268
Best recollection is that all are battery sets. The 38 and 38A differ in that the 38A has a ballast tube so that the filaments can operated from a higher voltage. Normally without the ballast tube is 2vdc. The "B" would indicate that it's a Baby Grand cabinet.
(This post was last modified: 05-25-2019, 02:51 PM by Radioroslyn.)
RE: 38, 38 A, 38 B - by Radioroslyn - 05-25-2019, 02:51 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9576 online users. [Complete List] » 1 Member(s) | 9575 Guest(s)
