Zenith 12H090
#62
Thanks Mike... I'll check a few things today, including line voltage, and the current it is drawing. Operation seems perfectly normal with no hum or distortion, and good clear FM. It doesn't need to run hard to fill the room with music.
Zenith 12H090 - by EdHolland - 05-27-2018, 03:11 AM
RE: Zenith 12H090 - by morzh - 05-27-2018, 11:30 AM
RE: Zenith 12H090 - by EdHolland - 05-27-2018, 07:54 PM
RE: Zenith 12H090 - by morzh - 05-27-2018, 11:14 PM
RE: Zenith 12H090 - by EdHolland - 05-29-2018, 01:51 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 05-30-2018, 02:26 PM
RE: Zenith 12H090 - by morzh - 05-30-2018, 04:51 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 05-30-2018, 06:26 PM
RE: Zenith 12H090 - by Arran - 05-31-2018, 04:42 AM
RE: Zenith 12H090 - by EdHolland - 05-31-2018, 04:08 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-01-2018, 01:41 AM
RE: Zenith 12H090 - by Arran - 06-01-2018, 02:15 AM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-01-2018, 03:39 AM
RE: Zenith 12H090 - by morzh - 06-01-2018, 07:55 AM
RE: Zenith 12H090 - by EdHolland - 06-01-2018, 12:43 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-01-2018, 03:31 PM
RE: Zenith 12H090 - by Arran - 06-02-2018, 03:06 AM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-02-2018, 05:48 AM
RE: Zenith 12H090 - by EdHolland - 10-25-2018, 11:51 PM
RE: Zenith 12H090 - by Arran - 10-27-2018, 04:09 PM
RE: Zenith 12H090 - by jcassity - 10-28-2018, 07:57 PM
RE: Zenith 12H090 - by EdHolland - 12-02-2018, 12:44 PM
RE: Zenith 12H090 - by EdHolland - 12-03-2018, 03:03 AM
RE: Zenith 12H090 - by EdHolland - 12-05-2018, 03:00 PM
RE: Zenith 12H090 - by EdHolland - 12-09-2018, 09:58 PM
RE: Zenith 12H090 - by Ron Ramirez - 12-09-2018, 11:17 PM
RE: Zenith 12H090 - by Arran - 12-10-2018, 05:34 AM
RE: Zenith 12H090 - by morzh - 12-10-2018, 09:20 AM
RE: Zenith 12H090 - by EdHolland - 12-11-2018, 02:05 PM
RE: Zenith 12H090 - by EdHolland - 12-16-2018, 11:45 PM
RE: Zenith 12H090 - by EdHolland - 01-13-2019, 09:37 PM
RE: Zenith 12H090 - by EdHolland - 01-20-2019, 11:20 PM
RE: Zenith 12H090 - by EdHolland - 01-27-2019, 10:35 PM
RE: Zenith 12H090 - by EdHolland - 02-01-2019, 05:06 PM
RE: Zenith 12H090 - by EdHolland - 02-02-2019, 10:26 PM
RE: Zenith 12H090 - by jcassity - 02-03-2019, 01:47 PM
RE: Zenith 12H090 - by EdHolland - 02-03-2019, 05:56 PM
RE: Zenith 12H090 - by EdHolland - 02-03-2019, 07:34 PM
RE: Zenith 12H090 - by jcassity - 02-04-2019, 11:55 AM
RE: Zenith 12H090 - by EdHolland - 02-04-2019, 03:29 PM
RE: Zenith 12H090 - by EdHolland - 02-08-2019, 02:37 PM
RE: Zenith 12H090 - by EdHolland - 02-09-2019, 11:17 PM
RE: Zenith 12H090 - by morzh - 02-10-2019, 11:19 AM
RE: Zenith 12H090 - by EdHolland - 02-11-2019, 04:04 PM
RE: Zenith 12H090 - by EdHolland - 02-12-2019, 01:27 PM
RE: Zenith 12H090 - by EdHolland - 02-18-2019, 02:36 PM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 03:17 AM
RE: Zenith 12H090 - by OldRestorer - 02-23-2019, 08:14 AM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 07:17 PM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 07:34 PM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 09:10 PM
RE: Zenith 12H090 - by OldRestorer - 02-24-2019, 03:02 PM
RE: Zenith 12H090 - by EdHolland - 02-25-2019, 06:34 PM
RE: Zenith 12H090 - by jcassity - 02-25-2019, 07:31 PM
RE: Zenith 12H090 - by tbone - 02-25-2019, 08:31 PM
RE: Zenith 12H090 - by Arran - 02-26-2019, 06:55 AM
RE: Zenith 12H090 - by EdHolland - 02-26-2019, 09:15 PM
RE: Zenith 12H090 - by OldRestorer - 03-19-2019, 01:01 PM
RE: Zenith 12H090 - by EdHolland - 03-19-2019, 09:36 PM
RE: Zenith 12H090 - by EdHolland - 05-26-2019, 12:46 AM
RE: Zenith 12H090 - by morzh - 05-26-2019, 08:32 AM
RE: Zenith 12H090 - by EdHolland - 05-26-2019, 10:48 AM
RE: Zenith 12H090 - by Eliot Ness - 05-26-2019, 11:11 AM
RE: Zenith 12H090 - by EdHolland - 05-26-2019, 09:22 PM
RE: Zenith 12H090 - by morzh - 05-27-2019, 10:43 AM
RE: Zenith 12H090 - by EdHolland - 05-27-2019, 11:48 AM
RE: Zenith 12H090 - by EdHolland - 01-12-2021, 08:45 PM
RE: Zenith 12H090 - by Arran - 01-13-2021, 12:31 AM
RE: Zenith 12H090 - by EdHolland - 01-13-2021, 11:33 AM
RE: Zenith 12H090 - by EdHolland - 01-16-2021, 09:58 PM
RE: Zenith 12H090 - by EdHolland - 01-21-2021, 08:25 PM
There are currently 9932 online users. [Complete List]
» 1 Member(s) | 9931 Guest(s)
