Difference between 41-295 and 41-300
I was wondering the same thing, about the additional tube in the 300, so thanks, Ron for clearing that up. After properly aligning my 295, it really pulls in distant stations at night, loud and clear. It's an amazing radio.
Henry, is it possible that the trouble is in the bandswitch? Have you tried jiggling it a bit to see how it affects the radio? The linkage is usually as sloppy as a 3-on-the-tree gear shifter, and the detent cam gets loose over time, causing inconsistent contact between the bands.
Difference between 41-295 and 41-300 - by hyounce - 11-28-2010, 02:02 AM
Re: Difference between 41-295 and 41-300 - by mgutierres - 11-30-2010, 01:12 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7896 online users. [Complete List]
» 1 Member(s) | 7895 Guest(s)
