Adapting a long-wire antenna to 41-295
Henry
If you want to add an external antenna to your 41-295, you have to make use of the small three-pin jack on the back of the chassis. You will also have to construct an adapter to connect to this jack.
Details here:
http://www.philcoradio.com/phorum/showth...p?tid=2599
More background info on this subject here:
http://www.philcoradio.com/phorum/showth...p?tid=1472
Re: Adapting a long-wire antenna to 41-295 - by Ron Ramirez - 11-30-2010, 02:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
