Philco VOM 7005
Hello. I've never seen a 7005 vom. and like you could find no mention or pic on the net.
I do have a model 7001 vtvm.
Here is a site you can get that manual at.> about half way down the page.
https://plymouthcolony.net/starcity/radi...nuals.html
Philco VOM 7005 - by jgumphress - 05-28-2019, 04:22 PM
RE: Philco VOM 7005 - by KCMike - 05-28-2019, 07:31 PM
RE: Philco VOM 7005 - by jgumphress - 05-28-2019, 07:40 PM
