Threads: 25
City: Louisville, KY
Well, I have a list I'm going to try to get pics of and send to my Aunt in Wales for identification, . . . unless anyone here can suggest something else I haven't thought of. I'm assuming their radio was imported from the US.
Here's the list :
35 , 36B, 38B (July 1933) , 34B (January 1934), 38B (January 1934), 34 B (June 1934), 38B (June 1934), 39B, and 38B (June 1935).
. . . all battery-operated models of cathedrals before mid-1935, when we know they already had it ( from a story of her knocking it to the floor off a table when she was 7 or so, and it still springing to life afterward.)
(This post was last modified: 05-28-2019, 11:41 PM by Jake Blake.)
RE: 38, 38 A, 38 B - by Jake Blake - 05-28-2019, 11:16 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9946 online users. [Complete List] » 3 Member(s) | 9943 Guest(s)
