Model 89 code 123 #36 tube
I am Restoring a model 89 with the usual coil problems.  I found good information on rewinding the # 14 oscillator coil.
I also have a bad secondary winding in the 1st if coil #18.  Did anyone save their notes on this coil?
I assume the wind is clockwise however does anyone have the number of turns and the wire size.
Is the wire size critical or is close enough ok?
Thanks for any help you can give me>
Tom
Model 89 code 123 #36 tube - by tmr63 - 05-30-2019, 01:26 PM
RE: Model 89 code 123 #36 tube - by Jake Blake - 05-30-2019, 04:44 PM
RE: Model 89 code 123 #36 tube - by Ron Ramirez - 05-30-2019, 05:34 PM
RE: Model 89 code 123 #36 tube - by tmr63 - 05-31-2019, 05:48 PM
RE: Model 89 code 123 #36 tube - by Steve Davis - 05-31-2019, 07:15 PM
91H Code 126 Restore
There are currently 4845 online users. [Complete List]
» 3 Member(s) | 4842 Guest(s)
