Crosley 124 detector plate choke
You may even be able to compensate for it's loss by increasing the value of that capacitor it connects to......it, also is tone control, and shunts high frequencies to ground.   That whole tone set-up there is odd to me though.
But  seems like a nice set,... with it's full-wave rectifier and push-pull output.
Crosley 124 detector plate choke - by jake wells - 05-30-2019, 01:41 PM
RE: Crosley 124 detector plate choke - by morzh - 05-30-2019, 03:17 PM
RE: Crosley 124 detector plate choke - by Jake Blake - 05-30-2019, 04:26 PM
