Crosley 124 detector plate choke
Mouser Electronics has plenty of 2.7 mH (2700 uH) chokes, probably close enough.
https://www.mouser.com/Passive-Component...h6Z1z0wph4
I would replace it with a new choke.
Crosley 124 detector plate choke - by jake wells - 05-30-2019, 01:41 PM
RE: Crosley 124 detector plate choke - by morzh - 05-30-2019, 03:17 PM
RE: Crosley 124 detector plate choke - by Ron Ramirez - 05-30-2019, 05:41 PM
There are currently 11076 online users. [Complete List]
» 2 Member(s) | 11074 Guest(s)
