41-285 84 Tube
Use diodes! They are CHEEP and easy to build a full wave rectifier . The 0Z4 will replace a 6X5, they both use the same socket, only the 0Z4 has no heater, and is really not all that reliable either!
I take the original 0Z4 tube can apart an install the diodes inside the can, looks 100% original !Works so well I give a Life time guarantee on my 0Z4 replacement.
I restore auto radios for a vintage Chevy/GMC truck parts supplier.
41-285 84 Tube - by dfields - 11-27-2010, 12:52 PM
Re: 41-285 84 Tube - by rghines1 - 11-27-2010, 03:28 PM
Re: 41-285 84 Tube - by codefox1 - 11-27-2010, 11:08 PM
Re: 41-285 84 Tube - by dfields - 11-28-2010, 01:13 PM
Re: 41-285 84 Tube - by 7estatdef - 11-28-2010, 10:28 PM
Re: 41-285 84 Tube - by Chuck Schwark - 11-29-2010, 11:38 AM
Re: 41-285 84 Tube - by Michael Dennis - 11-29-2010, 12:43 PM
Re: 41-285 84 Tube - by dfields - 11-29-2010, 07:12 PM
Re: 41-285 84 Tube - by dfields - 11-29-2010, 07:38 PM
Re: 41-285 84 Tube - by 7estatdef - 11-30-2010, 10:07 PM
Re: 41-285 84 Tube - by BILL - 12-01-2010, 06:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
