Bought my first cathedral.
Some military gear from the 50's and 60's is 120vac 400cy. Pt are dinky and useless... The point is that the core and windings on a pt need to be resonant at the frequency on the power that is being supplied to it. Else it just gets hot and angry.
Bought my first cathedral. - by jake wells - 06-01-2019, 07:45 AM
RE: Bought my first cathedral. - by Ron Ramirez - 06-01-2019, 07:56 AM
RE: Bought my first cathedral. - by Radioroslyn - 06-01-2019, 08:02 AM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 08:08 AM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 08:09 AM
RE: Bought my first cathedral. - by morzh - 06-01-2019, 11:18 AM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 12:56 PM
RE: Bought my first cathedral. - by Ron Ramirez - 06-01-2019, 01:36 PM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 01:49 PM
RE: Bought my first cathedral. - by Jake Blake - 06-01-2019, 02:01 PM
RE: Bought my first cathedral. - by David - 06-01-2019, 02:43 PM
RE: Bought my first cathedral. - by Jake Blake - 06-01-2019, 02:49 PM
RE: Bought my first cathedral. - by Radioroslyn - 06-01-2019, 03:05 PM
RE: Bought my first cathedral. - by Jake Blake - 06-01-2019, 03:11 PM
RE: Bought my first cathedral. - by Radioroslyn - 06-01-2019, 03:36 PM
RE: Bought my first cathedral. - by Jake Blake - 06-01-2019, 03:45 PM
RE: Bought my first cathedral. - by morzh - 06-01-2019, 04:53 PM
RE: Bought my first cathedral. - by GarySP - 06-01-2019, 05:00 PM
RE: Bought my first cathedral. - by Radioroslyn - 06-01-2019, 05:15 PM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 05:33 PM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 07:20 PM
RE: Bought my first cathedral. - by morzh - 06-01-2019, 07:59 PM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 08:03 PM
RE: Bought my first cathedral. - by morzh - 06-01-2019, 08:11 PM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 08:17 PM
RE: Bought my first cathedral. - by Radioroslyn - 06-01-2019, 08:36 PM
RE: Bought my first cathedral. - by jake wells - 06-01-2019, 09:00 PM
RE: Bought my first cathedral. - by David - 06-04-2019, 09:28 PM
Philco 91 Tuning Condenser
