Update: 42-380 First timer with a few questions
Thanks for the laundry list and awesome directions, as I look forward to my upcoming project. Your finished cabinet is very inspiring. From what I can gather, it looks as though I've got a good foudation as my cabinet is in very sound shape. The veneer replacing your photofinish looks amazing, I hope I can achieve results as outstanding as yours. Thanks again, and so, my adventure begins.
Re: Update: 42-380 First timer with a few questions - by baggrr00 - 12-03-2010, 02:07 AM
There are currently 9076 online users. [Complete List]
» 2 Member(s) | 9074 Guest(s)
