38, 38 A, 38 B
Yes  Terry...thanks. I will be calling upon your help more if this thing comes to pass.
'The 19 tube in the audio output is hungry current "
I'm kinda surprised we don't see more of this twin amp-stage triode for push-pull outputs....seems like a great space-saving tube to use.
38, 38 A, 38 B - by Jake Blake - 05-25-2019, 01:27 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 05-25-2019, 02:51 PM
RE: 38, 38 A, 38 B - by Jake Blake - 05-25-2019, 06:41 PM
RE: 38, 38 A, 38 B - by Phlogiston - 05-25-2019, 07:01 PM
RE: 38, 38 A, 38 B - by Jake Blake - 05-25-2019, 08:34 PM
RE: 38, 38 A, 38 B - by Jake Blake - 05-28-2019, 11:16 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-04-2019, 02:35 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-04-2019, 08:29 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-04-2019, 08:34 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-04-2019, 10:33 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-04-2019, 11:10 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-05-2019, 05:41 AM
RE: 38, 38 A, 38 B - by Jake Blake - 06-05-2019, 10:32 AM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-05-2019, 10:53 AM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-05-2019, 12:25 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-05-2019, 12:27 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-05-2019, 12:44 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-05-2019, 01:11 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-05-2019, 03:15 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-05-2019, 03:17 PM
RE: 38, 38 A, 38 B - by Radioroslyn - 06-05-2019, 06:36 PM
RE: 38, 38 A, 38 B - by Jake Blake - 06-15-2019, 12:53 AM
There are currently 9846 online users. [Complete List]
» 1 Member(s) | 9845 Guest(s)
