Grunow 1151 console
Was given a Grunow 1151 console a while ago it has been sitting in the garage and I thought why not bring it upstairs and clean it up a bit to see what it looks like. This thing is heavy as he__. The cabinet is not the best I will clean it up and see. What do you guys know about these radio sets? It has 3, 45 tubes in it I think. The speaker is not original to the radio but there is a tall thing on the bottom of the cabinet that hooks up to the speaker. This part might be why the radio is so heavy. Whatever you can tell me about the set will be helpful. Thanks in advance!
Grunow 1151 console - by PhilcoJohn - 06-06-2019, 06:29 AM
RE: Grunow 1151 console - by Radioroslyn - 06-06-2019, 09:17 AM
There are currently 10565 online users. [Complete List]
» 2 Member(s) | 10563 Guest(s)
