RCA 811k expert advice needed
Seems it is mostly due to interference coming from within the 4 walls of my house.
Have found similar problems with other radios.
Time to run an outdoor long wire I guess.
murf
RCA 811k expert advice needed - by murf - 06-11-2019, 05:28 PM
RE: RCA 811k expert advice needed - by Chas - 06-11-2019, 09:09 PM
RE: RCA 811k expert advice needed - by murf - 06-16-2019, 09:30 AM
RE: RCA 811k expert advice needed - by EdHolland - 06-17-2019, 08:52 PM
There are currently 10216 online users. [Complete List]
» 1 Member(s) | 10215 Guest(s)
