RP-1 connected to pilot FM tuner
Short answer - no.
The RP-1 produces an AM signal in the neighborhood of 550 kc (it is adjustable, but will remain in the lower end of the AM band), which cannot be received on an FM tuner.
Re: RP-1 connected to pilot FM tuner - by Ron Ramirez - 12-07-2010, 04:12 PM
