Zenith Chairside
I picked this up today. Its a Zenith 6s249 chairside radio.  A full checkup and recap will be happening soon.
[Image: https://i.imgur.com/c5nKuL3.jpg?1]
[Image: https://i.imgur.com/CSRBdVG.jpg?1]
[Image: https://i.imgur.com/iwjAwOM.jpg?1]
Zenith Chairside - by rdnzl - 06-17-2019, 07:26 PM
RE: Zenith Chairside - by Eliot Ness - 06-17-2019, 07:33 PM
RE: Zenith Chairside - by rdnzl - 06-17-2019, 07:35 PM
RE: Zenith Chairside - by Paul Philco322 - 06-17-2019, 08:37 PM
RE: Zenith Chairside - by rdnzl - 06-18-2019, 11:02 AM
RE: Zenith Chairside - by EdHolland - 06-18-2019, 11:48 AM
RE: Zenith Chairside - by Jake Blake - 06-18-2019, 12:16 PM
RE: Zenith Chairside - by morzh - 06-18-2019, 01:14 PM
RE: Zenith Chairside - by rdnzl - 06-18-2019, 08:10 PM
RE: Zenith Chairside - by rfeenstra - 06-18-2019, 08:13 PM
RE: Zenith Chairside - by Jake Blake - 06-18-2019, 10:03 PM
RE: Zenith Chairside - by morzh - 06-19-2019, 08:44 AM
RE: Zenith Chairside - by Ed Locker - 06-19-2019, 08:59 AM
RE: Zenith Chairside - by rdnzl - 06-20-2019, 04:59 PM
RE: Zenith Chairside - by Paul Philco322 - 06-21-2019, 11:05 AM
RE: Zenith Chairside - by rdnzl - 06-26-2019, 08:50 PM
RE: Zenith Chairside - by Jake Blake - 06-26-2019, 09:00 PM
RE: Zenith Chairside - by morzh - 06-26-2019, 10:13 PM
RE: Zenith Chairside - by Art Hoch - 06-28-2019, 08:08 PM
There are currently 10546 online users. [Complete List]
» 2 Member(s) | 10544 Guest(s)
