RP-1 connected to pilot FM tuner
I was thinking along the lines of the outputs on the pilot tuner (6 and 7) to the cartridge wires on the RP-1.. i have an i pod with head phone booster jacked to it then to the RP-1 and my 40-180 gets a good strong sig .......I don't want to receive the signal from the RP-1 i want to send to it ...the pilot tuner is a t601 and has a jack that came with it that would attach to the phono input of radios that had one factory installed..
I have 2 RP-1s one you have to tune the radio to 1400 kc range to pick up the signal from the RP-1 ...
I discovered that when i thought the RP-1 (that i had just got) was not working until i tuned the dial on my Stromburg Carlson to around that range ...
Re: RP-1 connected to pilot FM tuner - by Howard Stricklin - 12-07-2010, 08:00 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 3132 online users. [Complete List]
» 2 Member(s) | 3130 Guest(s)
