Zenith Chairside
The speaker aims front, center, behind the "rings"
My wife likes it.
[Image: https://i.imgur.com/D7nHVjK.jpg]
Zenith Chairside - by rdnzl - 06-17-2019, 07:26 PM
RE: Zenith Chairside - by Eliot Ness - 06-17-2019, 07:33 PM
RE: Zenith Chairside - by rdnzl - 06-17-2019, 07:35 PM
RE: Zenith Chairside - by Paul Philco322 - 06-17-2019, 08:37 PM
RE: Zenith Chairside - by rdnzl - 06-18-2019, 11:02 AM
RE: Zenith Chairside - by EdHolland - 06-18-2019, 11:48 AM
RE: Zenith Chairside - by Jake Blake - 06-18-2019, 12:16 PM
RE: Zenith Chairside - by morzh - 06-18-2019, 01:14 PM
RE: Zenith Chairside - by rdnzl - 06-18-2019, 08:10 PM
RE: Zenith Chairside - by rfeenstra - 06-18-2019, 08:13 PM
RE: Zenith Chairside - by Jake Blake - 06-18-2019, 10:03 PM
RE: Zenith Chairside - by morzh - 06-19-2019, 08:44 AM
RE: Zenith Chairside - by Ed Locker - 06-19-2019, 08:59 AM
RE: Zenith Chairside - by rdnzl - 06-20-2019, 04:59 PM
RE: Zenith Chairside - by Paul Philco322 - 06-21-2019, 11:05 AM
RE: Zenith Chairside - by rdnzl - 06-26-2019, 08:50 PM
RE: Zenith Chairside - by Jake Blake - 06-26-2019, 09:00 PM
RE: Zenith Chairside - by morzh - 06-26-2019, 10:13 PM
RE: Zenith Chairside - by Art Hoch - 06-28-2019, 08:08 PM
