Philco 144 question
Maybe I read your post wrong; are you asking about a filter choke or the 2nd IF transformer?
If you can find a junk Model 34, it will yield the IF transformers you want. I might even have a 2nd IF from one; I will look and see.
Any 460 kc IF that will fit should work okay; but for authenticity, you'll want one from a 34 or 144.
Philco 144 question - by TA Forbes - 12-09-2010, 10:43 AM
Re: Philco 144 question - by Ron Ramirez - 12-09-2010, 11:23 AM
Re: Philco 144 question - by Ron Ramirez - 12-09-2010, 11:36 AM
Re: Philco 144 question - by TA Forbes - 12-09-2010, 08:38 PM
Re: Philco 144 question - by TA Forbes - 12-09-2010, 08:46 PM
Re: Philco 144 question - by Ron Ramirez - 12-09-2010, 10:28 PM
Re: Philco 144 question - by TA Forbes - 12-09-2010, 10:45 PM
Re: Philco 144 question - by TA Forbes - 12-10-2010, 06:44 PM
Re: Philco 144 question - by Chuck Schwark - 12-10-2010, 11:36 PM
Re: Philco 144 question - by Ron Ramirez - 12-11-2010, 08:00 PM
