  • 1 Vote(s) - 3 Average
Nathan's Philco 201X Cabinet - Seeking Advice
Nathan,
I'm not one to put band aids on a wound that needs stitches. Why not strip it down and start anew? Since the trim is toner, I think you'd get away with just doing the top by itself. Certainly would be easier. But I'd do a complete job on the top.
Here's a pic of the one I did (I did the entire radio).
Pat
[Image: https://hosting.photobucket.com/images/r...fit=bounds]
RE: Nathan's Philco 201X Cabinet - Seeking Advice - by Patrick - 06-25-2019, 07:44 AM
