47-1230 transformer
Ellis,
I didn't need the transformer part number, as it is listed in the parts list of the Service Bulletin, but that is correct.
The 32-8248 is a vertical mounting type. with mounting centers of 2-1/2" x 2-1/4"
Height = 3-7/8" / Length = 3-1/2" / Width = 3-7/32"
Note: The voltages listed are for a line voltage of 115 volts (1947 remember).
Primary - 115 VAC
Secondaries:
High Voltage - 675 VAC @ 100 ma., center-tapped (330v - 0 - 330v)
Rectifier - 5 VAC @ 2 Amp
Filament #1 - 6.4 VAC @ 2.5 Amp
Filament #2 - 6.4 VAC @ 0.6 Amp, center-tapped
(Used expressly for the two audio output tubes)
Check out PlayThings of Past ( http://oldradioparts.com, and Radio Daze ( http://radiodaze.com ) for a replacement transformers.
Also use your favorite online aution and wanted listings for a junker chassis.
Regards,
Chuck
47-1230 transformer - by ellisnbetty - 12-09-2010, 05:44 PM
Re: 47-1230 transformer - by Chuck Schwark - 12-09-2010, 06:26 PM
Re: 47-1230 transformer - by ellisnbetty - 12-09-2010, 06:55 PM
Re: 47-1230 transformer - by Chuck Schwark - 12-09-2010, 08:25 PM
Re: 47-1230 transformer - by Don Lind - 12-10-2010, 10:12 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7232 online users. [Complete List]
» 4 Member(s) | 7228 Guest(s)
AvatarAvatarAvatarAvatar
