Airline 04WG-731B
This week's progress was checking tubes and starting on the capacitors. We got the replacement multicap can out and after getting the duct tape gunk off saw that an 80/80/50/50uF rated for 200v/200v/200v/50v was in there (original was 80/40/20/20 rated ?/?/?/?). Antique electronics has a 33/33/47 rated for 160v that I think I could use and then tack in an 80 separately.
Does anyone have a thought on whether the 160v rated caps are OK to use to replace the 40/20/20 sections...see schematic. Thanks!
Airline 04WG-731B - by klondike98 - 06-25-2019, 07:32 PM
RE: Airline 04WG-731B - by Paul Philco322 - 06-25-2019, 08:57 PM
RE: Airline 04WG-731B - by Radioroslyn - 06-25-2019, 09:34 PM
RE: Airline 04WG-731B - by klondike98 - 06-25-2019, 11:11 PM
RE: Airline 04WG-731B - by Paul Philco322 - 06-26-2019, 07:08 PM
RE: Airline 04WG-731B - by klondike98 - 06-28-2019, 02:08 AM
RE: Airline 04WG-731B - by morzh - 06-28-2019, 11:00 AM
RE: Airline 04WG-731B - by klondike98 - 07-02-2019, 06:50 PM
RE: Airline 04WG-731B - by klondike98 - 07-03-2019, 08:02 PM
RE: Airline 04WG-731B - by Steve Davis - 07-04-2019, 09:50 AM
RE: Airline 04WG-731B - by klondike98 - 07-04-2019, 10:04 AM
RE: Airline 04WG-731B - by klondike98 - 08-09-2019, 05:18 PM
RE: Airline 04WG-731B - by Eliot Ness - 08-09-2019, 05:38 PM
