TH14 cabinet/chassis layer
H**l. I've run into this on the Zenith TO. It is fraying and not in good condition. I definitely don't want to try and remove it but I read where you can paint over and seal it in.
Thank you for the help.
TH14 cabinet/chassis layer - by WyTex - 07-04-2019, 04:54 PM
RE: TH14 cabinet/chassis layer - by Radioroslyn - 07-04-2019, 05:50 PM
RE: TH14 cabinet/chassis layer - by mikethedruid - 07-04-2019, 07:12 PM
RE: TH14 cabinet/chassis layer - by WyTex - 07-05-2019, 05:30 AM
RE: TH14 cabinet/chassis layer - by WyTex - 07-05-2019, 09:43 AM
RE: TH14 cabinet/chassis layer - by klondike98 - 07-07-2019, 03:18 PM
RE: TH14 cabinet/chassis layer - by Ron Ramirez - 07-07-2019, 03:32 PM
RE: TH14 cabinet/chassis layer - by WyTex - 07-08-2019, 11:00 AM
