  • 1 Vote(s) - 3 Average
Nathan's Philco 201X Cabinet - Seeking Advice
Thanks Brad - yeah after reading about it a bit more I think I should have tried that. I may still do that but since I've got the base finish on I'm going to see how noticeable it is with toner.
Easy enough to strip and try the oxalic acid if it doesn't.
RE: Nathan's Philco 201X Cabinet - Seeking Advice - by Nathan Slingerland - 07-07-2019, 12:09 AM
