Emerson 25A restoration
I have finally gotten back to this little Emerson 25A.  I did get the capacitor-voltage drop components into place, replaced the choke with a new one and got it fired up successfully.  Unfortunately by the time I had it all back together and buttoned up I realized I had not taken any photos of the chassis...  Icon_e_sad  It plays OK although at relatively low volume.  I only have a short 10' antenna so longer would help some as well but I've played with this one enough so ... done for now.  I left the finish pretty much original.  It was dirty and the original clear lacquer had started to alligator a bit so I very lightly sanded, did a little restore-a-finish treatment, let that dry and then added a few coats of clear gloss lacquer.  I think it came out surprisingly well.  The grill cloth was replaced with the original grill cloth that I had taken out of the Emerson 250AW that I had worked on previously.
[Image: https://www.dropbox.com/s/18bs8n0tqcj394....jpg?raw=1]
[Image: https://www.dropbox.com/s/xjmmpcjlubhtf9....jpg?raw=1]
Emerson 25A restoration - by klondike98 - 08-30-2018, 10:18 PM
RE: Emerson 25A restoration - by Radioroslyn - 08-30-2018, 11:26 PM
RE: Emerson 25A restoration - by Paul Philco322 - 08-31-2018, 12:06 PM
RE: Emerson 25A restoration - by klondike98 - 08-31-2018, 12:20 PM
RE: Emerson 25A restoration - by Eliot Ness - 08-31-2018, 12:40 PM
RE: Emerson 25A restoration - by morzh - 08-31-2018, 01:19 PM
RE: Emerson 25A restoration - by Radioroslyn - 08-31-2018, 02:58 PM
RE: Emerson 25A restoration - by klondike98 - 08-31-2018, 06:48 PM
RE: Emerson 25A restoration - by klondike98 - 09-02-2018, 09:23 PM
RE: Emerson 25A restoration - by klondike98 - 09-05-2018, 10:28 PM
RE: Emerson 25A restoration - by Radioroslyn - 09-06-2018, 10:34 AM
RE: Emerson 25A restoration - by klondike98 - 09-06-2018, 12:37 PM
RE: Emerson 25A restoration - by klondike98 - 07-08-2019, 10:21 AM
RE: Emerson 25A restoration - by Eliot Ness - 07-08-2019, 11:01 AM
RE: Emerson 25A restoration - by mikethedruid - 07-08-2019, 04:11 PM
RE: Emerson 25A restoration - by OldRestorer - 07-09-2019, 12:09 AM
