Philco 38-17F Variant - another undocumented set
Here is my reply from E-bay....
"Thanks for letting us know about a listing or seller you'd like us to
investigate for potential fraudulent activity. eBay is very concerned
about this type of activity. We'll review your report as soon as
possible, usually within 72 hours.
Because we're concerned about the privacy of all parties involved, we
won't be updating you about the status of our investigation. Even though
you'll receive only this acknowledgement of your report, please be
assured that we'll thoroughly investigate the situation. "
Yea right. I feel very assured...not.
Oh well, I feel better now, off to start on the 39-55.
Happily back in Illinois..not.
Re: Philco 38-17F Variant - another undocumented set - by Glenn Roberts - 12-10-2010, 05:24 PM
There are currently 10547 online users. [Complete List]
» 2 Member(s) | 10545 Guest(s)
